Detroit Truetrac, weak? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2010, 02:34 AM
Cridder's Avatar
Last journal entry: 310 Small Block Chevy
detroit true trac, truly a weak sister, pictures too
Are they any good ? IMO no no no no they are not. I ran one in a 12bolt under my 1978 Jimmy. I didnt have big tires (33s) or a big motor (310 sbc) and i popped that thing like crackin a walnut, I thought i was gona bust a U-joint long before the truetrac ever gave me a problem, was i ever wrong.
I think a quik locker is a way better way to go.
Don't do it man steer clear there a time bomb,,, Eaton / Detriot should be ashamed of themselfs for not maketing this as a light duty use only unit.
I've run a quicklocker on the street for must be 15 years now in my 63 f-100
with 500hp 461 bbc 4spd and 3.25 9".....and i have at times punished that thing, works just fine on the street.
Name:	July 2009 097.jpg
ID:	49206   Click image for larger version
Name:	July 2009 087.jpg
ID:	49207   Click image for larger version
Name:	truetrak pics 010.jpg
ID:	49208   Click image for larger version
Name:	truetrak pics 007.jpg
Old 10-25-2010, 06:28 AM
Crosley's Avatar
Wiki Edits: 1659
Cridder;
Welcome to Hotrodders.com
I split off your post to a new thread. You posted to an old thread and this way we can have a new discussion on this subject.
Old 10-25-2010, 07:52 AM
TrueTrac is a fine piece for many uses, especially circle track and road racing. They have a one year warranty also, if that helps.
For serious off-road use, a locker or spool is the only answer
Old 10-25-2010, 06:14 PM
S10xGN's Avatar
Gotta love a turbo!
Hmmm, wonder if they're getting their castings from China...
Russ
Old 10-25-2010, 06:51 PM
SSedan64's Avatar
Russ
Casting grain looks cheesy. I talked to a guy from Eaton a while back, He said the TrueTrac was stronger than the Eaton Posi.
Old 10-25-2010, 09:20 PM
prostreet6t9's Avatar
Differential/Driveline
What were you doing when it broke?
Honestly..........
