Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Detune 388 Stroker
Old 11-12-2012, 06:01 PM
bj383ss bj383ss is offline
Detune 388 Stroker
Hello All,
Was looking for some advice on a cam selection.
Here is my current setup:
388 stroker
bored over .060
Speedpro powerforged flat top pistons with 6 cc 2 valve
Eagle 5.7" rods and forged crank
deck clearance .010
Felpro head gaskets 1003
Edelbrock Perf RPM heads 64cc
Comp 268XE cam and springs
Edelbrock Perf RPM intake with Holley 4160
Edelbrock double roller chain
Milodon high vol oil pump, windage tray, 7qt deep sump pan
MSD 6AL and Procomp billet dist
Hooker Header 1 5/8" with 2 1/2" Flowmaster 40's
79 Caprice 4 dr. TH350 built with shift kit, 2,000 B&M converter and 3.42 gears. The car weighs 3600lbs empty.
I am going to pull the engine and swap out the pistons to these:
Sealed Power #844-8-KH859CP60
383ci w/5.700'' Rod, Hypereutectic Pistons, .060'' Overbore
Piston Dia.: 4.060''
Piston Top: -12cc Dish, 2-Valve Reliefs
Pressed or Floating Pin
Comp Ratio: 10.28:1 w/58cc Heads, 8.65:1 w/76cc Heads
5/64'', 5/64'', 3/16'' Chrome-Moly Rings
These should net me right around 10.1 CR
I also want to change the came to the Comp cams XE252H. Will this cam work ok. I really want to de tune this combo as it is to radical and I want to just make a strong daily driver. I built this engine when I was a teenager and Hot rodded alot.
Thanks for your help.
