Originally Posted by bj383ss
I know the car is not tuned right. I have been messing with it for the last year and still don't have it driveable. I just dropped the tank and drained out all the gas as it was past its prime and causing it to blow white smoke.
Over the last year I rewired all of the underhood wires and installed the Procomp distributor to work with the MSD. I guess I need to start at square one on tuning. I know the distributor is in right. I have messed with the timing from 8* up to 18* and it is just rattling the valves not matter where it is at. I also put some octane booster in the tank but that didn't help either. The vacumn advance is working properly and I have tried ported and manifold source with no difference.
I feel like I have a timing issue of some kind.
What FI would you recommend?
Bret
BACK THE TRUCK UP!!! you're "rattling the valves"? what is that supposed to mean exactly? What gas are you running in it? BTW off the shelf octance booster isn't worth anything, so save your money.
