Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Detune 388 Stroker
Old 11-12-2012, 07:03 PM
hcompton's Avatar
hcompton hcompton is online now
Old & Furious
Dropping the tank is the right thing to do gas can go bad very quickly these days best to clean the system and start fresh. It can also pick up a lot of water.
Did it run any better. Whats the timing set at. Did you retune the distibuter and vacum advance/mechanical advance systems for high compression big cam? You should be able to run flat tops with Edel heads.
Have you tried pulling some timing out of it and a lot less advance and moving your vacum soure to a different port.
