Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Detune 388 Stroker
Old 11-12-2012, 08:17 PM
bygddy bygddy is offline
Proud LOSER
Start at the beggining, find true TDC with a stop, then confirm your timing marks at the balancer, get it advanced to app 14 to get it up and running. Make sure your vacuum advance is dissconected and capped. Worry about that later...assuming stock curve in your Pro comp dist with 14 initial it should be around 34 total, plenty safe with halfway decent gas. If it still "rattles" lets check lash, is it way loose and that's your noise? If the timing is confirmed correctly I would pull a valve cover and and check that as silly as it sounds.....
