Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Detune 388 Stroker
Old 11-12-2012, 07:46 PM
ap72 ap72 is offline
Banned
Originally Posted by bj383ss View Post
It does have fresh 93 has in the whole system. I have never rebuilt the carb. It has less than 30,000 miles on it, but has sat for the last 8 years started about once a month
I have not messed with the dist it is stock. I tried ported and manifold vacuum. The vac adv is not adjustable
Bygddy you mentioned the valve lash. I readjusted them last year. I did it while running with a half turn past zero lash. Now I'm wondering of I need to readjust them. They valve train is noisy but it always has been with the edelbrock valve covers
start it at 1/8 turn past zero lash- it doesn't take much preload at all. And your carb definitely needs some good attention. you need to get it clean enough to bring into a surgical suite. Freaken immaculate. Then bring it back to stock specs and increase the jet size just a little to be safe.
