Bodiebyes it has good oil pressure. 80psi when cold and about 60-65psi when warmed up.
I cut the oil filter open today. I didn't see any large pieces of metal in the filter media. However the oil at the bottom which was about a 1/2" deep had a metallic tint to it. Very small particles. I have never cut a filter open is this normal? The oil I drained out of the filter before cutting it open was fine just a little dirty.
Looking for advice from here. If the small particles are normal, then I am going to put a set of rebuilt 882 heads I have on and change the came to a small RV. Make it basically into a stock engine.
Bret
