Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Detune 388 Stroker
  #44 (permalink)
Old 11-18-2012, 06:32 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is online now
quote
(I guess it is possible the chain has stretched. This is the third engine I have had it in. Although it has less than 30,000 miles. My last 2 stroker motors went right after 10,000 miles. The first one threw the #1 rod. That's when I upgraded the rotating assembly in the second motor. It had the edelbrock cam that was from china and had a cam lobe go flat chew up the lifter and flush it threw the motor.)
you should post this on all the boards you see asking for "cheap" parts ideas
