Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Detune 388 Stroker
  #46 (permalink)
Old 11-25-2012, 03:53 PM
bj383ss bj383ss is offline
Well made some headway today. Started the engine up to operating temps. Shut it down and starting pulling spark plugs and valve covers so I could adjust the valves.
I FOUND MY PROBLEM!
#2 cylinder has some issues.
Broken pushrod and 2 rocker arms off. No wonder it ran like crap. It also split the pushrod guide in 3 places. It marred the edge of the valve tip but I think it is ok. A couple of the other rocker arms on this side were very loose. SO I guess when I adjusted the valves I obviously did it incorrect. So I am going to pull the intake to get the rest of the pushrod.
I hit the intake valve using a block of wood and hammer and it went down and back up fine so I am hoping it is not damaged.
When I pull the intake I am going to pull each lifter out individually and see if any are damaged. Hopefully this will only need a pushrod and new guide.
Thanks to all those who have been giving advice.
Bret
