Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Detune 388 Stroker
  #50 (permalink)
Old 11-29-2012, 03:44 PM
bj383ss bj383ss is offline
Well I was adjusted the valves per the link CDminter59 posted. I put it on TDC and adjusted both valves on #1. Went to turn the over till the #8 intake valve was at full lift so I could adjust #5 and noticed that the #8 intake was bearly going down. Skipped thought maybe it was really lose and the same problem with #7 intake. It went down a little then up a little then down.
So I pulle the intake and found 6 bad lifters. One is not concave yet but it had a really bad burr and I had a hell of a time getting it out. Had to pull all of them out with pliers.
So with this much material gone from the lifters I am assuming that all the bearings are probably bad and I am looking at a total rebuild again.
I'm not sure what happened. Did I adjust the lifters to tight and cause this failure. If anything I thought I had them to loose. But this explains why the valvetrain was so noisy and the rattling I heard.
I will definately say this is the last hot rod cam I will ever run. If I rebuild I am putting everything back to stock!
ID:	69456   Click image for larger version
