Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Detune 388 Stroker
  #64 (permalink)
Old 04-01-2013, 07:04 AM
33Willys77's Avatar
33Willys77 33Willys77 is offline
Do you realize all that metal has run through that motor? Your oil pump and bearings are going to be chewed up and you are going to be back in this motor again shortly. Once you have a cam go out (in your case a pretty bad situation), the engine will need to be cooked clean again. Someone should have steered you in this direction - there is still a lot of metal floating around in there - all those oil passages. How did the cam bearings look?
