Hey guys,
Quick question, I can pick up a set of DeVilbiss finishline HVLP guns for the same price as a sharpe finex. (my friend can get me cost as he works for napa). Finex is $97cdn while the Finishline is $105cdn
Which gun(s) is the best? I'll be using it for painting small things. I realize that my compressor will be running alot as its small (20gal, 7.4@40psi, 5.7@90psi), but i wont be painting a whole car, ect.. so i can somewhat live with it.
Should I end up getting the Finishline kit (includes 2 guns w/ 1.4 and 1.8) or get the Finex and get a larger tip/needle set for primer?
Finishline Kit Contains:
NOTE: I heard that there are no rebuild parts are available for this gun. Is this a major thing that I need to worry about? I would only be using it a few times per year. Hopefully these guns are reliable.
1 Full Size FINISHLINE HVLP Gravity Feed Paint Spray Gun with a 1.3mm (Finish Coat) Fluid Tip and a 600cc (20 oz.) Plastic Cup. This 1.3mm set-up is ideal for the Atomization of Basecoats, Clear Coats, and other Light Viscosity Coatings. Spray Gun Specifications: 30 PSI inlet pressure delivers 10 PSI air cap pressure at 13 CFM air volume.
1 Full Size FINISHLINE HVLP Gravity Feed Paint Spray Gun with a 1.8mm (Priming) Fluid Tip and a 600cc (20 oz.) Plastic Cup. This 1.8mm set-up is ideal for the Atomization of Primers, Sealers, Thinned Latex/Oil Base, and other Medium to Heavy Viscosity Coatings. Spray Gun Specifications: 30 PSI inlet pressure delivers 10 PSI air cap pressure at 13 CFM air volume.
Also Includes:
* 1 Gun Cleaning Brush Set
* 1 Gun Maintenance Wrench
* 1 Blow-Molded Storage and Carrying Case.
FX300 HVLP Spray Gun - 1.4mm
Sharpe SHP248756 - FX300 HVLP Spray Gun - 1.4mm
* Well-balanced and lightweight for reduced painter fatigue.
* High-end features at an affordable price.
* Parts for all spray guns readily available - repair instead of replace and extend the life of the spray gun.
* Includes durable, aluminum cup.
* One year limited warranty on all Finex products.
* Fluid Tip Size: 1.4mm.
* Air Consumption: 11.4 cfm
* Max Inlet HVLP psi: 29
* Weight: 24 oz.
* Air Inlet MPT: 1/4"
