Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - devilbiss finishline or sharpe finex?
Old 03-13-2007, 05:24 PM
oldred oldred is offline
Don't know why someone has not said this already but none of those guns will work with that compressor. That thing is for pumping up tires and is woefully inadequate for a HVLP paint gun. If you insist on using that tiny compressor you will need a low volume conventional gun, even that is going to be tough going, because any of the guns you mention will drain that little compressor in a matter of seconds, you can not spray paint when you run out of air.
