Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Dexcool. Did I just flush money??
  #16 (permalink)
Old 02-15-2013, 03:06 PM
RatPin RatPin is offline
Originally Posted by sbchevfreak View Post
Pulling the hose won't get all of it. You need to have it flushed, or pull the block drains out, and run water through until it runs clear, and then for 10 more minutes. Dexcool is junk, and is the subject of a class action lawsuit in regards to gasket failure.
Well I was hoping that since I have never ran the engine that the block would not be filled yet. In fact I never even topped off the radiator. I put in two gallons of the orange and still could not see collant at the top of my radiator filler neck.
I was thinking to pull that lower hose, drain the orange stuff, put the hose back on, fill with water, drain that water, fill with water and drain a second time then fill'er up with the green stuff. Hopefully that will be enough. I cant imagine it circulated too far without actually starting the engine.
Am I wrong?
The Following User Says Thank You to RatPin For This Useful Post:
41pu (03-18-2013)
