Dexcool in Gen 1 SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2010, 11:26 AM
I am rigging up a 350 SBC (aluminum heads and intake) for a buddy and he wants to put in some Dexcool coolant from Halvoline, I heard of some horror stories with the newer Ls engines. Should we get rid of the dexcool and get some good old green stuff? Thanks
Old 05-22-2010, 11:52 AM
The horror stories about this stuff are real. Works well when it works, but the slightest entry of air into the cooling system sets off a colossal chain of destructive events. This is made for people who buy cars like they buy toasters, purchase and use for a hundred thousand miles without ever peaking inside. For tinkerers that will undoubtedly drain and refill the cooling system for modifications to the engine or maintenance on the cooling system, Dexcool just isn't the stuff to use as once it's contaminated it turns to thick corrosive gunk. Go with Prestone (Ethylene glycol, poisonous) or Sierra (Propylene Glycol, not so poisonous). Or with Evans for a waterless antifreeze/coolant.
Use only distilled water to dilute the water mix antifreezes. Tap water is highly destructive to aluminum engine parts it contacts.
Bogie
Old 05-22-2010, 01:47 PM
302 Z28's Avatar
FWIW, I have Dexcool in all my vehicles (even the 34) and have had for a number of years, never had any problems with it. Prestone now has a 100K coolant that works well also.
Vince
Old 05-22-2010, 04:49 PM
Hippie's Avatar
Last journal entry: HEI comparison.
I've purchased a couple used cars that had Dex Cool and the cooling system was a mess. Took me forever to get it cleaned out. Good old Ethylene Glycol for this guy.
Old 05-22-2010, 05:08 PM
Bogie
How well does that Evans work, because here it can go down to -40 in the winter and as well as 90 inland during the summer months. Thanks
305 sbc harmonic ballancer and a 350 sbc ballancer blackie350 Engine 2 02-17-2010 01:34 PM
LT1 Intake on gen 1 SBC airboat Engine 11 01-19-2010 10:27 PM
BBC vs SBC mount locations & dimensions? y5e06 Hotrodding Basics 7 11-17-2009 11:10 AM
sbc 350/400 heads help Jwhite Engine 6 09-04-2005 05:56 PM
Late model 350 SBC Question Smoker113 Engine 3 02-19-2005 10:12 PM
