dexronII or merconV AOD - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2007, 02:58 PM
SuthnCustoms's Avatar
Crazy Ole Ironhead
My son has an 84 F150 with a bad AOD trans,i have a wrecked 85 GT mustang with a good AOD,i told him to swap that into it.
Question is,in the Haynes manual for the truck it lists ..
C4,C6,AOD..
1980....Dexron II
1981 on....Mercon
The mustang manual lists..
C3,C4,AOD and A4LD transmissions..
Through 1987......Dexron II
1988 on....Mercon
Being the same trans i dont know why they list Dexron II in the mustang instead of Mercon.(this one is an 85)
We looked at the casting numbers and everything its all the same.
I know ford now has a TSB to use the Mercon V now in place of any Dexron III/Mercon.
I already have a case full of Castrol Mercon V he could use,will it be OK to use it in the mustang AOD even though the manual says Dexron II?
Old 08-24-2007, 05:23 PM
aka Duke of URL
DEXRON II/DEXRON III and MERCON are all the same (differences are marketing names) (III replaces II in DEXRON).
I have also read the FORD TSB where MERCON V replaces all previous fluids (except TYPE F). I have a fresh case of MERCON V here that states it replaces DEXRON/MERCON.
________________________
06-14-4 MERCON ATF IS BEING REPLACED BY MERCON V ATF AS A SERVICE FLUID.
Publication Date: June 29, 2006
FORD: 1980-1997 Crown Victoria
1981-1997 Mustang, Thunderbird
1981-2003 Escort
1986-1993 Festiva
1986-1997 Taurus
1989-1997 Probe
1994-1997 Aspire
1995-2000 Contour
1980-1996 Bronco
1981-2003 F-150
1981-2004 E-Series, F-Super Duty
1983-1996 Ranger
1986-1996 Aerostar
1991-1997 Explorer
1993-2004 F-53 Motorhome Chassis
1995-1998 Windstar
1997-2004 Expedition
2000-2005 Excursion
2001-2007 Escape
1987-2000 F- & B-Series
2000-2007 F-650, F-750
LINCOLN: 1980-1997 Town Car
1981-1997 Continental
1993-1997 Mark VIII
1998-2004 Navigator
2002-2003 Blackwood
MERCURY: 1980-1997 Grand Marquis
1981-1997 Cougar
1986-1997 Sable
1987-1999 Tracer
1995-2000 Mystique
1999-2002 Cougar
1993-2002 Villager
1997 Mountaineer
2005-2007 Mariner
MERKUR: 1985-1989 XR4TI
This article supersedes TSB 01-15-7 to update the vehicle application chart.
ISSUE:
MERCONŽ Automatic Transmission Fluid is being replaced by MERCONŽ V as a service fluid.
ACTION:
Beginning immediately all automatic transmission / transaxle applications requiring MERCONŽ can now be serviced using MERCONŽ V or MERCONŽ Automatic Transmission Fluid or dual usage fluids labeled
MERCONŽ / MERCONŽ V. After July 1, 2007, MERCONŽ Automatic Transmission Fluid will no longer be manufactured, therefore, availability of this fluid will only continue for however long it takes to deplete what remains in inventory.
SERVICE PROCEDURE
Service automatic transmissions requiring MERCONŽ with MERCONŽ V or MERCONŽ Automatic Transmission Fluid or dual usage fluids labeled MERCONŽ / MERCONŽ V
For proper fluid application on current and past model vehicles equipped with automatic transmissions / transaxles refer to the fluid usage chart. (Figure 1)
CAUTION: AUTOMATIC TRANSMISSIONS / TRANSAXLES THAT REQUIRE MERCONŽ V SHOULD
STILL ONLY USE MERCONŽ V OR DUAL USAGE FLUID LABELED MERCONŽ / MERCONŽ V.
CAUTION: MERCONŽ SP, MOTORCRAFT PREMIUM AUTOMATIC TRANSMISSION FLUID AND MOTORCRAFT M5 ATFS ARE UNIQUE FLUIDS AND MUST BE USED IN APPLICATIONS RECOMMENDING THAT PARTICULAR FLUID. USE OF ANY OTHER FLUID MAY CAUSE REDUCED FUNCTIONALITY OR TRANSMISSION DAMAGE.
CAUTION: THE FUNCTIONAL CHARACTERISTICS OF FLUIDS FOR CVT TRANSMISSIONS ARE VERY DIFFERENT THAN THOSE OF OTHER AUTOMATIC TRANSMISSION FLUIDS (ATFS). USE OF
A FLUID OTHER THAN MOTORCRAFT CONTINUOUSLY VARIABLE CHAIN TYPE TRANSMISSION FLUID OR ONE LABELED AS MEETING MERCONŽ C WILL CAUSE FUNCTIONALITY CONCERNS AND INTERNAL TRANSMISSION DAMAGE.
CAUTION: DO NOT USE AUTOMATIC TRANSMISSION FLUID SUPPLEMENTS, ADDITIVES, TREATMENTS OR CLEANING AGENTS.
PART NUMBER PART NAME
XT-2-QDX MERCONŽ (Quart)
XT-2-DDX MERCONŽ (55 Gal. Drum)
XT-5-QM MERCONŽ V (Quart)
XT-5-DM MERCONŽ V (55 Gal. Drum)
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service.
The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
I feel uneasy about it also...
Old 08-24-2007, 06:14 PM
Crazy Ole Ironhead
I THINK i understand what there tryin to say..Mercon V replaces any trans calling for Dexron II/III and Mercon.
BUT...there is transaxles that call for the Mercon"C" and Mercon"SP" and Motorcraft M5 ATFS and not recommended to use Mercon V for them..
Bottom line.it only replaces any Dexron II/III and Mercon...
Which in our case saying its recommended to use it for the AOD.
I happen to be in town today where my buddy owns a trans shop and he said the same thing,he says thats all he uses in these trans. if the owners permit the extra money for it..plus he said he will warranty a trans. longer if using the Mercon V in place of the Dexron and Mercon and even longer if they decide full synthetic,so were actualy doing the right thing..thanks KULTULS!!
John
Old 08-24-2007, 08:17 PM
aka Duke of URL
Excerpt From TSB;
John
MERCON V is a synthetic. Guess FORD tired of marketing both. I am sure you can still get DEXRON III from any major refiner. The price of the stuff seems to have come down also.
I need to check if it is recommended for PS fluid also.
AOD to 312 57 T-bird BarryK Transmission - Rearend 1 03-09-2008 03:24 PM
Replacing C4 with AOD Mustang50Clay Transmission - Rearend 5 05-04-2004 06:24 PM
My AOD, the full story mustang66maniac Transmission - Rearend 26 01-30-2003 05:38 AM
AOD lost 4th gear ford5.0supercharged Transmission - Rearend 13 10-16-2002 05:42 PM
AOD Metric mustang66maniac Transmission - Rearend 4 08-05-2002 11:52 PM
