I just pulled my engine that I overheated and noticed a few other things when I pulled it and wanted to see if you guys could help me correct the problem. Temps have always seemed to run correct but overheating was caused by the lose of a lower water hose and didn't notice till it was to late, engine started to rattle.ain:
Engine has 50,000 miles on a rebuild,.030.
90% driving is on Highway- average about 700miles a week.
84 c-10, chevy truck Daily Driver
87 octane
Crate 350/350 turbo set up, 31"tires
HEI- 14 degrees intial,10 degrees vaccum advance, 34 total
Quadrajet
EGR
CCS-2 Mellings Cam SAE Specs@ Gross Center
Duration @.50 Cam Lift Duration Lift valve lift Line
CCS-2 INT. 194 258 .260 .390 108 HYD.
EXH. 202 269 .273 .409 116 HYD
http://www.melling.com/Portals/0/Size Charts/Stock Cam Specification Chart.pdf
Stock engine specs
87 octane
Quadrajet
EGR
Stock engine specs
Ok, heres the question/problem. The center of the heads look to be heating up too much and I am thinking the problem might be timing related or EGR related(new EGR)? Heres a photo of what I am seeing. The center of the heads has been BURNING oil at the black area. Seems its been getting hot enough to burn the valve gasket alsil changes were done regulary in the begining but lately for the last 3-4 months Ive been loosing a quart of oil every 2-3 weeks from leaks so I just been adding a quart.
