Diagnose my 700R4, lost 3rd and 4th ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2013, 11:55 AM
461 Big Block 700R4 Tranny with about 3 seasons on it..
I am going to a local car show and enjoying the ride. I got on it a few times no issues... Now I am doing about 45 and I get on it, and I see a small cloud of smoke, burning smell (like oil) then my RPMS shoot up... Pull over, I have 1st and 2nd, no 3rd and of course no overdrive, what did I break?
Thanks guys in Advance for the comments......
Old 05-18-2013, 02:14 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
3-4 clutch pack is likely toast, burned up , junk.
Where the shift to 3rd gear would be, does the engine rev up? Or simply no shift from 2nd gear?
Old 05-18-2013, 02:52 PM
JeffB's Avatar
I agree 3-4 clutch pack is a goner a full overhaul is on the menu now,TV cable adjustment is critical on GM and Ford overdrives.If you used the LOKAR TV cable KD-2700 and bracket SRK-4000 the bracket is only held down by one Carb stud they will work loose and change the throttle pressure (BAD design) in any case something has probably caused that adjustment to change and fried the transmission.You might want to consider this upgrade into the rebuild:1987-92 GM 700R4 Constant Pressure Valve Body
Old 05-18-2013, 07:03 PM
Engin revs up!!!
Old 05-18-2013, 07:41 PM
I like the idea of the new Pressure Valve Body
TV Cable Pic Bracket...
Old 05-19-2013, 05:37 AM
So in your opinion, do you think it was an issue with the tv cable or could it have been the torque being generated?
Thanks in advance for all your help guys..
Old 05-19-2013, 12:20 PM
JeffB's Avatar
Your bracket looks fail-safe, these O.D. transmissions should always be set using a pressure gauge for positive results. Excessive heat is also a common culprit, the stack type transmission coolers that B&M and others offer is cheap insurance and a "must have" for performance or towing applications.
Old 05-19-2013, 01:38 PM
I have a Transmission cooler and a gauge, The gauge was indicating normal operating temperature, however when the incident occurred the temperature indicator shot up into the yellow, however it never hit the red zone....
Old 05-19-2013, 01:40 PM
I have had this combo for two seasons now....Do you think the motor was to strong for the tranny?
Old 05-19-2013, 02:21 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
possible the torque and heavy foot can hurt the trans quickly if the trans is not build properly and TV cable not set correct ..
also remember this design trans has been burning up the 3-4 clutch pack since 1982. You are not special in this failure
Old 05-23-2013, 07:28 AM
Pulled the pan today and found the following:
Appears to be like Gasket like material
Metal
Now I was also told over on Team Chevelle it's a possibiliy the Gear on the Governor could have caused this issue as well. I will be pulling the governor today, any thoughts?
700r4 no od/3rd 4th gear stevetankl Transmission - Rearend 3 09-20-2012 11:40 PM
4L60E Auto box now lost 2nd 3rd & 4th UKwheels Transmission - Rearend 8 08-11-2010 06:30 PM
3rd to 4th - 700R4 87GMC Transmission - Rearend 4 06-02-2009 07:28 PM
700r4 has no 3rd or 4th gears mattgabe Transmission - Rearend 5 06-27-2006 07:59 PM
91 Caravan lost 3rd/4th gear tm454 Transmission - Rearend 8 01-01-2004 02:57 PM
