Diagnosing oil use bad on sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2013, 03:30 AM
sqeezeit's Avatar
Hello all, I have sbc in bros hot rod and is using alot of oil,so is it rings,valve seals/guides? Actual mileage unkown but in hot rod from older couple bought last year,so I dont think its alot...but never know.Anyways want to diagnose to see which it is without tearing whole motor apart first.How can one or best way to test for each?
Old 10-12-2013, 08:01 AM
delawarebill's Avatar
engine check
u can do a leak down test, but u need valve and gage and stuff to do it. easy thing is compression test x2.. do a test the way it sits, then put in about a table spoon of oil into the cyl and run it around a few times to seal the rings. do the test again and compare the readings. with oil and if it goes up 20 or 30# or more then its the rings. stays the same (more/less) it'll be in the valving seats and can require a valve job and guide work.
Old 10-12-2013, 08:36 AM
jokerZ71's Avatar
Wrench Turner
You could also have an intake gasket leaking.The leakdown test would be a more accurate way to pinpoint the problem if you can't figure it out from a compression test.The 1st thing you should do is pull the sparkplugs & examine them so you see which cylinders may be getting oil thru them.
Old 10-12-2013, 08:59 AM
sqeezeit's Avatar
I don't see how a valve job would make a difference unless guides are so bad causing seals to wear bad . Also I hav done compression tests before on known good motors then added oil to cylinders and rose more then 30 before. Plus I would think most leak down tests would be for checking the valves leaking more then anything?
Old 10-12-2013, 09:02 AM
RWENUTS's Avatar
First thing I'd do is the free no frills, no tools required clean up of the engine from top to bottom, back to front until it's spotless. THen start it up and find where it's leaking.
Rule of thumb from years ago!
'One drip every 100 feet burns a quart of oil every 1000 miles'!!
Cure the oil loss due to leaks first then if it's still bad do the leakdown and compression tests to pinpoint it.
Old 10-12-2013, 09:07 AM
sqeezeit's Avatar
Hotrod is spotless with zero oil or anything for that matter on it anywhere
Old 10-12-2013, 09:09 AM
sqeezeit's Avatar
Just curious how leaking intake would work, if it's leakin inside that would also mean it would have a vacuum leak inside and have drivability issues but it runs great
Old 10-12-2013, 09:10 AM
jokerZ71's Avatar
Wrench Turner
On a compression test,you want to ck for uniformity between cylinders rather than any specific psi.It could be seals alone,or,seals & guides.Or as I said earlier,an intake gasket could be allowing your intake valves to suck oil into cylinder.A leakdown test is usually done after a compression test to help pinpoint problem area.Inspecting plugs will also show if certain cylinders are more of a problem than others.There are a # of reasons a motor uses oil.Even a plugged PCV system.The above test are starting points to help determine where your problem may be.
Old 10-12-2013, 09:14 AM
jokerZ71's Avatar
Wrench Turner
How much oil is the engine using ?
Old 10-12-2013, 09:18 AM
jokerZ71's Avatar
Wrench Turner
Not necessarily.The oil being pulled thru on a very small leak can mask the effects of the leak making it not as noticeable.
Old 10-12-2013, 09:20 AM
RWENUTS's Avatar
Awesome!!
Try the 4 dollar (a gallon of gas)no tools test.
Get your bro' to follow you down the road. Find a road with a steep hill on it.
Going down back off on the loud pedal and if it's smokin' blue out the pipes it's bad guides. Going up the hill if it's pushing blue it's bad rings.
I'm not being a wisea---s. Just old guy field tests before you spend the money in the wrong place.
Old 10-12-2013, 09:21 AM
sqeezeit's Avatar
understand, but just not following how leaking intake gasket would be and still run fine with no signs of lean condition or eratic idle,ect..is all
Old 10-12-2013, 09:22 AM
sqeezeit's Avatar
It uses a quart+ in less then 250 miles
Old 10-12-2013, 09:25 AM
sqeezeit's Avatar
Originally Posted by RWENUTS View Post
Awesome!!
No i hear ah the simple things sumtimes work,but all I know is it smokes when u first start and after that cant really tell.I know you would think with that much oil use it would smoke the skeeters away,but dont really see much.
Old 10-12-2013, 09:30 AM
sqeezeit's Avatar
I was thinking this also but have never seen it, but anythings possible. With a small use I would think maybe but dam with that much oil use a guy would think it would run like shiz also
good oil pressure bad oil on rockers makennoise Engine 2 12-27-2011 12:20 PM
Diagnosing engine noise SBC 350 DQ81 Engine 29 02-05-2011 03:53 PM
What oil pump would be good for 350 SBC? Heard bad news about melling eric32 Engine 10 02-15-2009 03:48 PM
Diagnosing week cylinders 350 SBC driveability Engine 59 03-02-2007 10:18 PM
Diagnosing Bad Catalytic Converter deleteall Engine 4 04-14-2003 05:43 PM
