Diagnostic Codes - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2005, 04:33 PM
Diagnostic Codes
Hi I need some help with a code 34-MAF (gm/sec HI). Vehicle is a 86 Pontiac Firebird Trans Am 5.0 liter TPI. What does this code actually mean Chilton books are very vauge. Any help would be appriciated thank you
Old 06-05-2005, 05:26 PM
1Fast65Elky's Avatar
Left Nut, Right Nut....Squish!
Since no ones answered yet.....
Just to tide you over, its something with the mass air flow sensor.
code 34: MAF sensor-voltage too low....
took this off google search: procedure for checking the MAF sensor:
1. Disconnect the sensor plug.
2. using a test light or multimeter check for power using the power wire(pink/black) and the ground wire(black/white) Test with key on, engine off.
3. Test for voltage(with a voltmeter or multimeter) between the yellow wire and the ground wire(black/white). This should be 5-6 volts.
If something doesn't test right. Look for a problem in the wires. If everything is OK, than the MAF sensor my be bad.
Someone else thats more expierenced sould chime in eventually
Have a better one.
Old 06-05-2005, 06:09 PM
Thank you very much. This sould help. I will let you know what I find. Again thanks
Old 06-07-2005, 11:21 AM
edge's Avatar
Time is short, are you ready?
You need to go to Thirdgen.org and join. As a member you can search a huge database. When performing a search on "code 34", it resulted in 556 hits!
Here are a few that may help:
http://thirdgen.org/techbb2/showthre...hlight=code+34
You will almost always find an answer for your 3rd gen F-body at www.thirdgen.org. If any of the above do not answer your question, join and do some more searching.
Best of luck, Ed www.edgesz28.com
Did You Know?
Old 06-07-2005, 12:13 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
Sorry HerTA that I haven't answered your PM, got busy If you have a fax # I will fax you the trouble code diag tree for this code.
Steve
Old 06-07-2005, 01:31 PM
edge's Avatar
Steve
The thread I linked above has the diagonstic tree and some other troubleshooting charts, etc. attached to it. Ed
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
1964 barracuda fender tag codes pugster Hotrodding Basics 1 05-30-2005 07:38 AM
Dodge puter codes 78 monte Engine 2 05-14-2005 12:20 PM
Weird stamping codes need help! Destructo Engine 4 09-16-2003 09:08 PM
GM 12 Bolt Housing Codes jbspringer Transmission - Rearend 0 10-03-2002 03:43 PM
