Hotrodders Bulletin Board > Tech Help> Engine
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 06-15-2006, 02:48 PM
88chevy 88chevy is offline
diagnostic codes
i pulled the codes out of my computer and got 23 manfold air temp (MAT) indicatin low temp what does that mean?
  #2
Old 06-15-2006, 04:46 PM
RHamm1320's Avatar
RHamm1320 RHamm1320 is offline
Last wiki edit: Computer dyno simulation and engine building softw... Last photo:
Wiki Edits: 3
Is the sensor itself bad? Or possibly a connection or the wiring?
Old 06-15-2006, 05:27 PM
edge's Avatar
edge edge is offline
Time is short, are you ready?
It means you read the code wrong or had the wrong VIN number(s) plugged in when connecting the scanner.
88' TBI with a Manifold Air Temp Sensor? Better check again. TBI systems for those year trucks did not include a MAT sensor. Try to buy one at the parts store and see what part no. comes up.
Ed
Old 06-15-2006, 06:02 PM
MAUSS MAUSS is offline
An '88 doesn't need a scanner... just jumper pins A & B on the ALDL connector with a paper clip and count the blinks on the Check Engine light (I've got an '89 GMC). Code 12 will blink 3 times and then any stored codes will blink. Code 23 is a Throttle Position Sensor failure.
Old 06-15-2006, 09:33 PM
sorry i wasn't specific the motor is from a 1992 chevy caprice cop car and im also using the cars computer on the truck too
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "diagnostic codes"
ThreadThread StarterForumRepliesLast Post
this is a saver.... GM build codesTooMany2countGeneral Rodding Tech2411-23-2009 10:36 AM
Diagnostic Trouble Codes - 1993 Taurus GLawbazarElectrical409-18-2005 09:09 AM
96 Silverado Pickup Diagnostic CodesDave DangerEngine1407-06-2005 09:57 PM
Diagnostic CodesDodge4x4DakotaElectrical506-07-2005 02:31 PM
Weird stamping codes need help!DestructoEngine409-16-2003 10:08 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
