Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > Garage - Tools
  #16
Old 01-11-2006, 01:06 PM
oldred oldred is offline
re: Diagnostic tools
I have the Autoxray, have had it for several years and even updated it. For home use it is a really good buy for the money.
Old 01-13-2006, 05:17 PM
dieselherb dieselherb is offline
scan tool
I have a program on my laptop that I purchased from Harrison R&D $140 it will work on anything 96 and newer. Web address is www.obdscan.net
Old 01-15-2006, 03:29 PM
56 Project's Avatar
56 Project 56 Project is offline
I work for the Town of Franklin, Ma.. We have the Genusis. We just had it updated with the latest updates which bring it up to the 2004 level. All of these scan tools run about 1 1/2 years behind on the updates. The genusis is fairly simple to figure out and can do alot with it. Our problem is the delay in getting updates as we have 2006 cruiser in our fleet and cannot communicate with the computer to check the codes in the computers.
Old 01-24-2006, 10:40 PM
TechnTool's Avatar
TechnTool TechnTool is offline
OldSchool MotorHead
Lotsa suggestions out there. check out this copy and past from a website
ScanPro OBDII CAN Scan Tool OTC3409
3409 OTC ScanPro is a multi-function tool that will retrieve all generic trouble codes for all foreign and domestic OBD II compliant vehicles as well as display selected enhanced codes for GM, Ford, Chrysler and Toyota and certain manufacturers specifi c codes for Asian and European vehicles. Monitors the performance of drive-train related components on all OBD II compliant vehicles including CAN-based vehicles. Read hard, pending, intermittent/memory and historic codes and show defi nitions Erase codes and reset MIL View and graph live data stream View freeze frame data Record, playback, and graph data User programmable hot key I/M monitor readiness test Off vehicle data review Printing capability (with optional printer) O2 monitor test Diagnostic monitor test On board systems Vehicle Information Modules present Functions on all OBD II compliant vehicles CAN capability Code look up through internal library of definitions Software upgradeable to support future vehicles and tool enhancements via fl ash programming Easy to use, menu driven software Large, 128 x 128 backlit graphic display with adjustable contrast Detachable cable 3 year warranty 3409 comes with: Computer hook-up cable CD with DTC LookUp Software 8 Foot OBD II cable 6 AAA batteries Padded nylon storage case
List Price Your Price Qty
$569.95
$327.74
Call OTC and see if something like this is what you are looking for. It looks like a little brother to the Genisys.
Old 01-25-2006, 08:59 PM
Gearhead55 Gearhead55 is offline
Gearhead55
Hey 92,
I have to agree with CrazyLarry.
Also have an Auyoxray.It should work
on all the vehicles you mentioned.
Gearhead55
Old 01-27-2006, 06:04 PM
fearsjlwolf's Avatar
fearsjlwolf fearsjlwolf is offline
scan tools
just got rid of a mastertech,looking for a buyer for my genesis.have had my modis for over a year now.will not trade this one in for anything!the modis is faster than the mastertech and the otc genesis.I use it at work and at home,thats why I invested so much money.for home use only I would recommend the genesis (good ones on fleabay).for around 800-1500.but for the work I do the modis is my tool of choice....wolf
Old 01-28-2006, 06:46 PM
xk8 xk8 is offline
OTC Nemisys?
Hey you guys what do you think about the OTC Nemisys? I am thinking about buying it for home use after comparing it against all the rest of the scanners on the market! thanks >>>>>>> Phil
Old 01-29-2006, 07:05 PM
andy vandervelde andy vandervelde is offline
diagnostic tools
the OTC genysis is an ok tool for basic OBD data but does not have any real diagnositcs on it. It also can't do a lot of the body, abs, parking aid etc. data links
Andy
Old 01-31-2006, 05:01 PM
dartshadow1 dartshadow1 is offline
YoungPuP454
I think it is going to be an issue
I know what you mean. I had an 06 in my shop the other day and had to send them to the dealer cause the scanner I had didn't work. A Code Reader didn't work, The shops scanner didn't work, Snap-on scanner didn't work and I got pissed off and sent them to the dealer, I got talking to one of my buds at the dealer and he told me that they are changing the protocal in the new vehicles coming out, anyone know what this is all about.?????? (Generic OBD2 didn't even work)
Old 01-31-2006, 05:05 PM
YoungPuP454
Just wondering
I have been doing a little research on the whole laptop and diagnostics with a laptop and wondering how long you have been using it for, I am interested in getting into reading codes and diagnostics from a laptop etc. Wondering what you think of the scan tool. Would you recemend this for a shop to use????
Old 02-14-2006, 01:18 PM
tcauto tcauto is offline
scan tool
in short i will give my 2 cents worth,i have used several scan tools and my vote goeas to the Genysis ,but i am partial to OTC my shop is pretty much Otc have always used them, also like the Tech 2 for GM's but Otc will handle most tasks
Terry
Old 02-01-2008, 10:47 AM
debeli debeli is offline
new car software!
ElsaWin,EsiTronic,Autodata,Alldata,Mitchell On Demand,Scania,MAN,Lorries,cars - all programs on one place!Come and visit us at
and see why has more than 2000 people gave their trust to us!They are already happy with thei car softwares - will you be?
Visit - ***********************
Contact: **************
Last edited by dinger : 02-01-2008 at 11:28 AM. Reason: Violation of guidelines. Please see: general board guidelines.
Old 02-07-2008, 08:12 PM
ernkazern ernkazern is offline
For what you're going to do you might try to pickup a used Genysis on Ebay. It would be a decent scan tool for your purposes. Another option, if you own a laptop and are comfortable using it, is software from Autoenginuity. It'll run circles around the Genysis, is cheaper to buy and has MUCH better tech support. OTC tech support is pathetic when compared to other proffessional diagnostic tool suppliers. Btw, the OTC lab scope for the Genysis is crap when compared to real professional grade lab scopes and it's the same or more money. I know, I own 3 scopes and I never use the Genysis one. It was like flushing money down the toilet.
Old 02-07-2008, 08:24 PM
In reply to DartShadow1's question, the new protocol is called CAN. I forget what it stands for but I'm sure you could Google it. Scan tools require special software to read the various inputs, outputs, and communications between the various modules on the newer CAN controlled vehicles. That isn't all that new either. I had an early 2000's Blazer in that I needed a CAN protocol scan tool to read the ECM. Newer scan tools can read both the info on older vehicles and the CAN info on newer ones. Autoenginuity makes software compatible with both for laptops. Btw, usually a "code reader" is a waste of money. A code only gives you an area to start looking at, the codes don't tell you what to replace or exactly what's wrong. They only tell you that an input or output is out of range.
Old 02-07-2008, 08:28 PM
CAN........Controller Area Network. Basically it allows the modules on a vehicle to communicate directly with each other without having to first communicate with a host module that in turn communicates with the others. The newer the vehicle the more modules it has on it, easily a dozen or more.
Back to top
This discussion has been added to the Garage - Tools Discussions category of the Hotrodders Knowledge Base.
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Diagnostic tools"
tool brand! Mr.NutCase Garage - Tools 48 02-08-2008 08:47 PM
Stinking Tools bukweet General Rodding Tech 26 12-18-2005 10:44 AM
Hotrodders Knowledge Base: Garage - Tools Jon Garage - Tools 0 11-26-2005 06:46 PM
Where to start: Tools Madd Syntst Hotrodding Basics 11 01-25-2004 07:41 PM
Question about what tools to use for body work? clutter_1968GTO Body - Exterior 2 06-12-2003 07:57 PM
