diagram for wiring up a toggle switch please - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2008, 04:59 AM
old jeezer's Avatar
hi guys, i'm installing a cooling fan. i need a diagram on how to hookup a toggle switch. can you help me out please????? thank you jeezer
Old 01-17-2008, 05:16 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
You need to use a relay as well as the toggle switch. Let the toggle switch activate a relay to cut your fan on and off. This way you will not be burning your toggle switch out all the time and may prevent a fire hazzard as well.
Old 01-17-2008, 05:27 AM
i agree with henry, use a bosch relay. you can wire it directly to battery power (with an inline fuse/circuit breaker) and use your toggle switch to ground the relay to turn it on. i don't have a wiring diagram in front of me but i can look it up tomorrow. the bosch relays have a standard 4 blade terminal hookup that is easy to wire and the fan load goes through the relay, not the switch.
Old 01-17-2008, 06:08 AM
79C10's Avatar
Viva la Migra!!
Single pole ,single throw , or double pole double throw , or single pole , double throw?????
There are a LOT of "toggle switches" out there.. what are you hooking up?
I'd go with the relay and forgo a "switch". What if you shut your car off , but it still needs to cool ? I hear electric fans kick on in cars that are parked , so I imagine it is necessary.
Good luck with your project.
Old 01-17-2008, 07:34 AM
302 Z28's Avatar
Take a look at these diagrams using relays.
Vince
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
Toggle switch voltage capacity for relay 1970Chevy Electrical 5 11-02-2007 04:56 AM
Toggle Switch for Windows Jagman06 Electrical 8 03-03-2007 08:40 AM
toggle switch / ignition switch help help! 39chevy Electrical 4 08-18-2006 06:04 PM
toggle switch on 700r4 Danscam Transmission - Rearend 3 06-21-2006 04:13 AM
