Dial indicator - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2009, 08:56 PM
Dial indicator
How do I repair the indicator on my steering column that indicates what gear I am in? Is it neccessary to take off my instrument panel? Do I have to unbolt the steering column? I am aware that the indicators fuctions on a cable that resembles a fishing line. My manual absolutly does not show a thing how to hook the doggone thing backup. I think it just popped off and is not broken. How do I reconnect. My vehicle is a 1987 5.7 chevy suburban. Auto trans of course. Let me slip this question in to. How do I adjust the indent cable? The cable is beginning to unwind where it is connected to my TBI. Some times when I am going up a steep hill the accelerator does not kick in to I guess what you would call passing gear or overdrive. Please give the the run down on this cable. The tranny is in good shape, I suspect the cable. Thanks
Tommy
Old 06-15-2009, 09:28 PM
fast68's Avatar
likes chevy trucks & boobies
to repair the cable no you just need to pull the lower panel under the column around it
to remove the indicator plate you have to remove the instrument bezel to get to the two screws that hold it to the dash cluster housing
anymore details needed lemme know
or pics i can take pics i have several 73-87 dashes laying around and plates also.
to reconnect it if the cable is not broken you simple pull the loer coverpanel under the column around it there and it either clips to the loer column housing at the dash,. or it is retained by a phillips head screw
both styles were used over the years and it will randomly have either style
most times the cable is frayed broken though
as for lack of kickdown if it is theoverdrive trans(700r4) then it is actually not a kickdown cable but rather a TV cable
if it is the 700r4 then you have to fix this asap as this runs the transmission and if it is badly out of adjutment or fraying then it can cause the trans to burn up the forward shift clutch pack due to sloppy slow shifts or cause undue strees due to too harsh of shifts.
it may have a 400 trans however
if it has no overdrive position
3L80HD in that case, a variant of the th400 starting in 87 and has a 27 spline output most were tag code LJA on the side of the trans i have two of them both from 87's
and they dont have a cable
so since you say you have a cable then it cant be the 3L80HD trans and must be the 700r4
buy a new cable for it at auto zone or napa etc and set it properly, ASAP
good luck
Old 06-16-2009, 09:34 AM
TV cable
Now you got me worried. I definitly have a TH700R4 trans. What are the signs that I hav'nt already burned up the shift plates? I just recently changed the fluid and it did not have a burned smell to it but never the less tell me more about this TV cable. What does TV stand for? I will get it repaired but I need information on how to adjust it.
Tommy
Old 06-16-2009, 12:48 PM
SSedan64's Avatar
TV cable = TV/ThrottleValve Cable >>>> "The TV cable used on the 4L60 (transmission AKA THM-700-R4), THM-200-4R & THM-200C controls line pressure, shift points, shift feel, part throttle downshifts and the detent downshifts."
http://purplesagetradingpost.com/sum...o/700R4p1.html
More Info., 3 Pages Part 1, 2 & 3 >> Throttle Valve Cable system 101
http://www.tvmadeez.com/article/index.php
Old 06-16-2009, 01:49 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Hey SS64, thanks for the links- lotsa good info there!
Old 06-16-2009, 03:29 PM
SSedan64's Avatar
It's a good Info link, no doubt. I think Crosley/Tony is to thank for most all the 700R4 Info, maybe much more. I haven't looked thru all of the other links yet. Check out the 2 links at the top of the page. There's all kinds of Great Info. & odd things. I like the Fool Injected 427. http://purplesagetradingpost.com/sum...carsindex.html and Crosley's Isetta/Erklemobile.
Todd
Old 06-16-2009, 03:40 PM
cranky1's Avatar
Just stuck
Thought this was going to be a question about machinist tools lol
Old 06-16-2009, 03:56 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Same here!
But, yeah. TONS of info, for example a LOT of SBC HEAD flow bench info.
I'd suggest folks bookmark the HOME PAGE so they can look everything over.
My aged AMES Dial indicator Rob Keller Garage - Tools 2 03-13-2008 03:32 PM
Dial Indicators chevyman992002 Garage - Tools 8 01-12-2008 07:30 AM
Need Advice on intake setup decathlete Engine 4 07-10-2007 06:25 PM
Can you use a dial indicator to measure deck height? Malibu73 Engine 9 10-26-2005 08:42 PM
finding the lift on my cam by using a dial indicator? Jacks77 Engine 13 09-13-2005 03:16 PM
