Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Diamond Tufting?
Old 07-10-2007, 07:14 AM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
Wiki Edits: 22
This is no easy one to answer. Do you want the tufts sewn in or folded in? In a nutshell: decide how big you want the tufts, both side to side and top to bottom. Usually tufts are a little taller than they are wide. Lay this out on the foam you are tufting the fabric to and mark the location of each button. After you cut the holes in the foam, the foam needs a good solid backing to hold the buttons. Using an arch punch, or some form of hole saw, cut a hole in each button location slightly larger than the buttons you plan to use. At the outside edges of the tufted area, you need to score the foam and let the excess fabric fold into the scoring, or fold the fabric on top of the foam without scoring the foam. It is trial and error to get the right distance of the fabric between the holes in the foam in both directions. Different fabrics tuft differently, and it has to look good to you, and there is no magic formula to determine that. Once you figure this out, transfer these dimensions to your fabric, put a button through the fabric and then through the hole in the foam and through the backing material. If you use eye buttons, do not tie off the buttons too tightly at this point, (use a mattress knot) or if you're using prong buttons, bend the prongs too tightly yet. Fold in all your tufts until they are uniform and then tighten down the buttons. Sewing in the tufts is different. If that's what you want to do I'll have to take some pictures to explain it. Are you talking about using real leather? Practice A LOT with some vinyl first. Buttons are hard to make out of real leather, and a lot of vinyls. The button dies have to be set up for it. If you have more questions, just ask. Good luck.
