Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Diamond Tufting?
Old 07-11-2007, 07:59 AM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
Wiki Edits: 22
the rest of the pics. You can see where I marked the pattern on the back of the vinyl, and then pushed a sharp point through the fabric to mark the fabric on the front side. This also makes pushing the buttons through the vinyl easier. Start tufting from the center row and work out to the ends. Then work up and down from the center out. Don't tighten the buttons down as tight as they'll go at first. Adjust the tufts and then tighten the buttons all the way. Like I said, this was done hurriedly, and could have been tweeked to let the fabric lay better, but you should get the idea.
ID:	22711   Click image for larger version
ID:	22712   Click image for larger version
ID:	22713   Click image for larger version
ID:	22714   Click image for larger version
