Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Diamond Tufting?
Old 07-13-2007, 07:02 AM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is online now
Wiki Edits: 22
I forgot to mention when I updated the posts that you need a solid backing to attach the buttons to. This can be cardboard strips, wood, heavy synthetic backing, a combination of the strips and backing material,whatever, but if the backing is weak, the tufts have no depth and look bad. I use a fabric called Versare to cover the back springs which makes an excellent backing, or I have also used Flex Pad, which is used more for seat springs than back springs. The first pic is Versare, which comes in 40" wide rolls. The second pic is the Flex Pad, which is made to be a padding over seat spring construction and comes in 20" and 24" wide rolls.
Also: I went back and edited my answer to Alan's question. Go back and take a look.
ID:	22735   Click image for larger version
