dics brake conversion suppliers ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-14-2010, 04:35 PM
I have a '69 Olds Cutlass, with 14 inch factory wheels, and power drum brakes. I'd like to convert it to power front disc brakes , if possible. What company sell a conversion kit for this ?
Old 12-14-2010, 04:50 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
http://www.yearone.com/serverfiles/f...ain2.asp?cat=3
Old 12-14-2010, 04:54 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
This is who i used for my camaro. http://www.ssbrakes.com/ .
Cole
Old 12-14-2010, 05:04 PM
The Cutlass uses the same disc brakes as a Chevelle. EVERYBODY sells these kits. I've found Speedway Motors to be the least expensive. You do not need a different power booster, you can use your old one if you have PB. You can also machine your drum spindles to accept the caliper brackets as shown here:
http://www.pozziracing.com/brakes.ht...Drums_to_Discs
Old 12-14-2010, 05:47 PM
I will check them out right now, thanks. Problem is.... most companys like Year One and OPG only sell parts for 15'' wheels.... as I said, at the top, mine are '14''
Old 12-14-2010, 07:19 PM
1ownerT's Avatar
Wiki Edits: 4
Really???
AB223P
This complete kit is designed to convert your front drum brakes to disc while fitting inside stock 14" wheels. Includes rotors, single piston cast iron calipers, pads, flex hoses, wheel bearings, power booster, master cylinder, hardware, mounting brackets and instructions.
Old 12-15-2010, 02:33 AM
www.koniksklassiks.com
810-394-4162
He specializes in 70-72 monte carlos.. he can set you up with a complete USED front brake setup from a monte carlo, which is the same as a 70-72 chevelle (not sure about the 68-69 chevelle) which should fit..
just an option
Old 12-15-2010, 10:18 AM
The factory 10.75" rotors came with 14" wheels. The problem is that not all 14" wheels are created equally. Drum brake cars got wheels with a different backside profile than disc brake cars. For example, the 1960s Olds Super Stock I wheels will not clear disc brakes, but the early 70s version (also 14") will clear the factory discs.
Old 12-15-2010, 11:41 AM
I'm sorry " T " ! I didn't see that one.... figured there had to be one somewhere.................thank you
Disc brake conversion kit Nichols6 Suspension - Brakes - Steering 3 11-23-2007 12:01 AM
drum to disc conversion kits dmented Suspension - Brakes - Steering 4 06-06-2007 10:06 PM
Corvair Disc Brake Conversion tcruise Suspension - Brakes - Steering 3 08-31-2005 01:16 AM
64 el camino brake conversion camino_man Suspension - Brakes - Steering 0 01-30-2004 07:01 PM
Disc brake conversion for a 67' mustang Pencilneck314 Suspension - Brakes - Steering 6 12-07-2003 03:24 PM
