Did a 1965 Ford Galaxie 500 XL come with a locking rear-end? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2005, 10:30 AM
63 Falcon with a 350's Avatar
I was wondering if a 1965 Ford Galaxie 500 XL with a 390 came with a locking rearend?
Please help because I wanna know before I buy this car.
Old 04-29-2005, 12:34 PM
Some did...........
Most did not.........
It should have a tag on the rear end........
It should have a " L " in the code...........like the above tag. The tag will also tell you the gear ratio.......
All of this IF the tag is there or has not been tampered with.........
Old 05-01-2005, 12:12 AM
comet boy's Avatar
When all else fails burn it
Last journal entry: more hiding stuff
Check the code on the drivers door. if the axle is a number, it is open. if it is a letter, than it is a posi unit. That is if someone hasn't changed it.
Old 05-06-2005, 10:31 AM
If the tags are gone you can jack the back up and spin a tire. If both spin the same direction it is a locker.
Bob
Rear end substitution 65 ford truck 1965fordtruck Transmission - Rearend 1 11-16-2004 12:03 PM
ford 9" rear end stangfiend Engine 4 10-10-2004 03:30 PM
Ford 9" Rear End Narrowing nightrain_rod Transmission - Rearend 3 11-30-2003 11:50 AM
1955 Ford Wagon Rear End . . . TorqueU Transmission - Rearend 2 10-04-2003 11:33 PM
Engine, tranny, rear end, ford CustomFord Engine 3 01-05-2003 11:25 PM
