Did I buy the wrong size harmonic balancer? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2012, 12:38 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
I pulled an 8" GM balancer of this SBC350 truck engine and got an SFI 18.1 approved Trick Flow unit that is 6.61" diameter. Will this work on a mild street motor (~400HP)? I am planning on the occasional surge to 6,500 RPM, but not sustained RPM usage. This is a complete rebuild of the motor btw so I do not want to risk any damage or hinder performance. It is going into an 81 Chevy C10 with manual trans and 3.73 posi out back.
Here is what I got sitting in the garage waiting to be installed: Trick Flow Specialties TFS-19000 - Trick Flow® Track Max® Harmonic Dampers - Overview - SummitRacing.com
It appears the only 8" balancers are GMPP (which I am thinking is the best option even though its not SFI) or some questionable Chinese units (Dorman, Prof Prod, SCAT, Pioneer), which I want to avoid altogether.
Take me to school on balancers!
Old 07-26-2012, 07:23 PM
BOBCRMAN@aol.com's Avatar
350 Chevy is neutral balance. ANY neutral balance unit will work on a street engine. As long as you can adapt the timing tab, pulleys, etc. to work with the small balancer. GM used small balancer for many years..
Old 07-27-2012, 11:01 AM
It seems like from what I am reading a larger diameter is more desirable for engine longevity. Smaller balancers are desirable on race engines where longevity is not an issue due to constant rebuilds.
I wonder if it is more of an issue of diameter or weight?
Old 07-27-2012, 12:31 PM
lg1969's Avatar
Google "Tunnel Ram 406"
I had no issues when i change the harmonic balancer on a 307 and replaced it with a 350 balancer. The timing was the same.
Harmonic Balancer Timing Mark...Wrong Location? GUITAR1989 Engine 29 11-05-2011 04:38 AM
Harmonic Balancer Size 383SBC Engine 8 03-23-2011 04:54 PM
harmonic balancer wrong? southshore30 Engine 8 02-19-2010 08:01 PM
What the ***** is wrong with my timing cover/ harmonic balancer!!! sexypizzaman Engine 56 10-28-2008 03:49 AM
harmonic balancer size... Trav Engine 6 10-07-2003 09:45 PM
