Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Did I overheat my engine?
Old 07-13-2008, 12:21 PM
Jmark's Avatar
Jmark Jmark is offline
Banned
Like the others have accuratly stated, you need to address the cause of the high temp in traffic.
262 is not critically overheated, especially since ( I hope) you have iron heads on the iron block. Where problems arise is when aluminum heads shift on an iron block, making a mess of head gaskets. But you will know more after you fire it back up after it cools. Hopefully, it will be fine. (I have 2 chevy trucks that will hit 250-260 on a long pull up a 6% grade in the summer with the A/C on. So far, no problems.
