Did the machine shop thrash my block? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-09-2012, 09:30 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
Originally Posted by F-BIRD'88
When you take it apart, to clean the block properly you can measure the piston pin height.
I bet you'll find it is 1.54". The last set of those pistons I used were 1.54"
piston Pin height ='s the distance from top of pin hole to piston top + 1/2 (half) the pin hole diameter.
Clean it all good and check the rings end gaps , bearings clearances (at least with plastigauge) and rod big end diameters. Reassemble correctly with a good torque wrench.
Use only engine oil and GM EOS as a assembly lube. But put moly cam lube on the cam lobes.
use a felpro 1094 gasket to get a .040" ish quench clearance if that what you are after.
I use this stuff to aid engine break in and protect cam+lifters etc from scuffing
It helps the rings break in as well, without scuffing etc.
it works.... leave it in for 1000 miles
www.molyslip.com Moly slip E oil supplement.
Auto trans fluid works good as a final wipe clean for cylinder walls
but then lube the cylinders with the motor oil+ GM EOS
(after you scrub the whole block with hot soapy water and blow dry w compressed air)
hmmm I think that gasket is a little too thin. Depending on the cylinder it would yield a squish of .028 - .042".
Thanks for the feedback about the fluids. I will add them to my shopping list.
  #17 (permalink)
Old 04-09-2012, 10:23 PM
RippinRon's Avatar
Then use victor 5746 .026" thick with a 4.1" bore.
  #18 (permalink)
Old 04-10-2012, 12:31 PM
OK I re-checked the numbers using a different technique and they all came back very similar if not the same. In fact when I average the first set of numbers, the second set larger by .001" on both left and right cylinder banks.
Left bank average is .022-.023"
Right bank average is .019-.020"
If the machinist took .020 off and the pistons are now known to be 1.548" CH, then that leaves a calculated clearance of .017". Oddly enough, the only cylinder to do this is the one that has the replacement rod. It is constant on the fore and aft measurement.
I know this probably seems trivial to you. But I am newbie and the only way I am going to learn how to build a proper engine is to sweat the details. If I don't pay attention now, then what good is it for my next engine? Perhaps part of the learning curve is selecting a good machinist and dealing with the ensuing disaster.
Welcome to the world of going nuts, You'll discover that we do a lot of measuring with a micrometer while cutting with an ax kind of stuff.
Yes finding a reliable machinist is one of the most fundamental efforts. With that are the tools to measure everything, given places like Harbor Freight it's a lot less expensive to by precision measuring tools than it was 50-60 years ago. These Chinese tools probably don't hold up for a life time but they are pretty accurate and will last for the sometime builder till you get going and can afford the high buck stuff.
Lots of good books out there on engine blue printing which will take you through the processes that insure an accurate and quality build. As an example; this book by Reher-Morrision is pricey but very current, it is written as text book so it goes in deliberate learning phases http://www.amazon.com/Reher-Morrison.../dp/0972343288 . Consider an investment in your automotive library to be as important as tools as it feeds your brain which is the tool you'll use the most often of all.
Bogie
  #19 (permalink)
Old 04-10-2012, 01:01 PM
Thanks for the book suggestion, Bogie.
I went back to the machine shop over lunch and discussed my gripe list. There were about 8 sub-par items. So I will be bringing the block back to them for correction. One of the items is that the decking operation destroyed an old helicoil cylinder head bolt hole. They are also going to measure the piston compression height as well.
They keep insisting I am asking tou much and that I am trying to build a nascar motor. I keep saying no, I need something between a granny grocery getter and nascar. We gotta find a good average between.
I appreciate all who have replied and are helping me out. Hopefully everything turns out OK on trip #2.
  #20 (permalink)
Old 04-11-2012, 02:12 AM
4 Jaw Chuck's Avatar
Have you considered the fact you keep getting different numbers when you check that perhaps your measuring apparatus or technique is the cause of all your grief?
Have you measured the deck heights from the crank centerline using a jig meant to support the weight of the block on a surface plate with a ground rod the exact size of your mains? Was any of this equipment calibrated to a standard?
What I'm getting at is you are measuring with assembled components with designed in clearances to permit proper running operation but your expecting measurements closer than 0.002" per bank?
Your chasing your tail dude.
— Han Solo
  #21 (permalink)
Old 04-11-2012, 03:02 AM
Nothing is trivial. As far as choosing a machinist pick the guy who who answers all your questions. A bad machinist will tell you that if he answered your questions you'll know what he knows. A really good machinist will tell you anything you want to hear because if you could learn all he knows during a 20 minute conversation, you'd be competing with him.
Need to get block to machine shop Big_Willy Hotrodding Basics 5 12-14-2011 05:12 PM
Fresh from the machine shop cleaning tips for engine block! 74chevyflat Engine 16 08-05-2010 09:34 AM
[ Searching for affordable machine shope to machine a Merlin aluminum bare block ] hannes_slanec Engine 3 01-03-2008 08:20 AM
LF machine shop wildtaxi21 Engine 0 09-21-2006 01:36 PM
going to the machine shop rustyrazer Engine 4 05-15-2003 07:02 AM
