Did Someone Tamper with My Starter? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2008, 11:15 AM
Last journal entry: Rear End Disassembly
My brother's truck wouldn't start one morning so he called me to come out. He lives in downtown chicago, it's a 94 ford ranger. After inspecting the starter, I noticed that the "ground strap" (the strap that goes from the solenoid to the starter motor, was cut in half. There are hundreds of thick strands and they all were cut down a perfect line. Could a short have caused this, breaking the strap like a fuse would? Or did someone actually get down there and cut it?
Old 06-17-2008, 12:11 PM
ceh383's Avatar
'51 Chevy 3100
If it burned like a fuse the ends would be melted, just like a fuse. Fuses blow when you have a short, how do you short a ground strap?
Old 06-17-2008, 02:10 PM
in my mind , your talking the hot wire , someone cut it if as described
nnnnnow for the ground strap by starter , it has no insulation on them , just a braided flat wire .
he could have hung it on something because there known to hang down a bit on them trucks .
Old 06-17-2008, 02:29 PM
I'm not sure if they call it a ground strap, which is why I put it in quotes, it looks like a ground strap, but just as burnt olds described, its a braided flat wire. definitely didn't get it caught on anything, he lives in the metro, nothing to get caught up on. And it was hard to tell if the ends were melted because the whole wire was filthy dirty.
Old 06-17-2008, 02:50 PM
Def sounds like the ground strap....If it was cut there should be some sort of marks right at the brake site.. pic's????
Old 06-18-2008, 01:03 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Some thieves will go under a vehicle and cut the ground strap or positive cable so as to disable the alarm system if they were stealing the truck, MAYBE??
Chevy 350 cracked starter mounting hole w pics skiprec Engine 14 11-11-2011 07:47 AM
Installing a mini starter on my Chevy vern kelly Electrical 5 09-09-2009 03:41 PM
Starter shifting and grinding.. new starter? Where does starter brace go? 84Z Engine 8 11-12-2007 03:44 PM
small blcok chevy! The ultimate starter problem! S.O.S. sugar ray Engine 11 07-19-2007 09:07 PM
Carry on from other Starter POST dollybud Electrical 0 09-26-2003 06:48 PM
