Die grinder and Aluminum - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2009, 06:54 PM
How can I use a die grinder with a carbide bit or a rotary file on aluminum without clogging up the bit ? Whats grinders grease? Do I need a special bit ?
Gene
Old 05-01-2009, 07:03 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
here is grinders grease hope it helps. http://www.eastwoodco.com/shopping/p...iProductID=969. Cole
Old 05-01-2009, 07:12 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Bits made to cut Al are designed w/flutes made for the purpose. Good ones are expensive.
Old 05-01-2009, 07:25 PM
powerrodsmike's Avatar
Wiki Edits: 161
I use a soft wax stick, rub a little on the aluminum before you start grinding and add a little now and then. The spray stuff works really good but is expensive. I scrub the wax into any finished welds before they cool all the way, it makes blending much easier, and you can use the double cut carbide burrs designed for steel.
They sell the wax at hardware stores, it's used for lubricating drawers and all kinds of stuff.
Use the wax or spray on abrasive discs too and they will cut for about 10x as long.
Later, mikey
BE different....ACT normal.
Old 05-01-2009, 07:50 PM
How fast is fast enough?
as long as you don't mind reapplying it often almost any oil will work, I've even used brake fluid before. Hell, even shortening will work. Some last longer between applications and that's where the real difference is.
Old 05-01-2009, 07:55 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
We use WD 40 when porting aluminum heads. But as was mentioned most any oil will work.
leldai73's Avatar
Its just metal,you're the boss
as was stated, any thing from wd-40 to Crisco will help. try a bit double cut flutes, and try running it slower by (assuming this is a pneumatic die grinder) regulating down the air pressure.
Old 05-02-2009, 10:16 AM
Great feedback , thanks for the response guys.
Gene
Old 05-03-2009, 07:58 AM
bentwings's Avatar
bentwings
Don't forget the saftey glasses. A face shield is even better.
Old 05-03-2009, 08:16 PM
I haven't had occasion to try it yet, but I was told the wax from a toilet seal works well.
Old 05-03-2009, 08:25 PM
cranky1's Avatar
Just stuck
WD-40 and a slower speed works for me too.....but not too slow. When machining aluminum on a lathe, I spool it up using WD-40. It's easy to cut and so long as you have some kind of lube, it'll come off well instead of it balling up on ya.
Old 05-03-2009, 08:40 PM
Wiki Edits: 161
Same stuff as the wax stick...watch the foreign matter though..
J/K
Later, mikey
Old 05-03-2009, 08:43 PM
302 Z28's Avatar
An old one
Vince
Old 05-03-2009, 08:44 PM
302 Z28's Avatar
And also should wear a dust mask.
Vince
Old 05-03-2009, 10:02 PM
OK, I'm cheap, but not that dang cheap! Anyway, the old ones are too much trouble to get out.
Yesterday morning I couldn't spell aluminum welding certified, now I R one! MARTINSR Body - Exterior 9 04-01-2009 10:42 PM
Adjustable Air Mini-Die Grinder (For Polishing_ fcastro Garage - Tools 13 11-09-2007 01:09 PM
my doors got stretched nomad57ry Body - Exterior 17 12-02-2004 06:51 AM
Grinding Aluminum Heads Mad Maggot Engine 14 11-17-2004 09:16 AM
