Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - diesel engine to gas conversion with T-400 trans
Old 04-15-2009, 09:27 AM
curtis73's Avatar
curtis73 curtis73 is offline
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
The micro switch will cause it to kickdown. Just get one, wire it up, (polarity doesn't matter - it just gives 12v+ to the terminal on the tranny when you floor it.) That will solve the no kickdown issue. The vacuum modulator needs to be replaced with one from a gas vehicle which should fix the early shift issue.
