Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - diesel engine to gas conversion with T-400 trans
Old 04-15-2009, 01:06 PM
fast68's Avatar
fast68 fast68 is offline
likes chevy trucks & boobies
hi there,
when the electric kickdown solenoid is connected to a kickdown switch it will no longer shift so early
what year truck we talking here/
if old body style 91 or older then you could pull a stock switch from the accelerator pedal assembly of any th400 truck 73-up and run the single wire from it to the solenoid spade on the trans
and run power to the switch to the fuse panel ign source same as what factory did.
doing the same in a 78 right now converting from the original th350 to a nice 3L80HD from an '87
good luck
