Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - diesel engine to gas conversion with T-400 trans
Old 04-15-2009, 09:04 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
the t-400 trans was set up to shift early with the diesel engines... that would be the governor and valve body too.
a modified governor would help for later shifts and that vacuum modulator as mentioned
