Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 01-03-2004, 01:45 AM
lbwireman's Avatar
lbwireman lbwireman is offline
diesel leak from injection pump or lines
I have a '91 F350 7.3L with a Banks turbo. Original mileage is approx. 105K, turbo was put on by Banks about 20K mi. ago. I've recently noticed a fuel leak that's causing the bottom of the injector pump and the "pan" below it to be wet with fuel. At first I thought it was coming from the juncture where the front of the pump mates to the adapter housing. However, after reading KULTULZ reply (Sep. 2002) to a question from snowman re: a similar problem apparently caused by leaking (loose) fittings on the bottom injector pump lines, I wonder if this may be my problem also. The truck still runs fine, although it's become a bit harder to start in the AM. One mechanic told me the pump needed to be replaced. Do these symptoms sound like a pump in need of replacement or simply some loose fittings? Thanx for your replies.
Old 01-03-2004, 02:17 AM
hugo`'s Avatar
hugo` hugo` is offline
New Member
re: diesel leak from injection pump or lines
Do you happen to have any pictures of the area wetted with fuel?
Sorry it's just hard to go by a discription over the internet. A picture seems to speak 1000 words.
Henry
Old 01-03-2004, 09:39 AM
reborn55 reborn55 is offline
Very possible for it to be leaking there. There are 9 lines there. you should be able to see it drip with the aid of a small mirror. Anytime there is a leak it can cause starting problems. Diesles don't like air in the fuel system.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
