Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Diesel shop compressor
Old 06-01-2009, 06:31 PM
61bone 61bone is offline
Last journal entry: frame build
Used to have a Jaeger 125 plumbed to the shop. Didn't use any kind of regulator except at the outlets that required it. Your air system doesn't recognize volume only pressure. I used it to run the bead and sand blasters and had a 22 cfm I used when I didn't need the large volume of air. If you ever get to the place where you need that much air, It'll take at least 1 1/4" air line to handle that volume.
