-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   Diesel shop compressor (http://www.hotrodders.com/forum/diesel-shop-compressor-159426.html)
930dreamer 06-01-2009 05:44 PM
2 Attachment(s)
Hello, I'm looking at a Joy diesel, trailer mounted air compressor. It's at least 150 CFM. Has anyone plumbed something like this for shop use? Can I reduce this into a working air volume with a large regulator? Thanks 930
61bone 06-01-2009 06:31 PM
Used to have a Jaeger 125 plumbed to the shop. Didn't use any kind of regulator except at the outlets that required it. Your air system doesn't recognize volume only pressure. I used it to run the bead and sand blasters and had a 22 cfm I used when I didn't need the large volume of air. If you ever get to the place where you need that much air, It'll take at least 1 1/4" air line to handle that volume.
930dreamer 06-01-2009 06:35 PM
I have a Jaeger with a 6 cylinder also. Engine is at the machine shop for a rebuild. 930
