Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Diesel truck, should I buy it???
Old 08-07-2006, 08:34 PM
Henry Highrise's Avatar
Henry Highrise Henry Highrise is offline
Lost in the 60's
Wiki Edits: 4
I have had that happen before........it turned out to be a bad check valve on the injection pump where the return line attaches.........the valve stuck open when the engine was shut off all the fuel in the injector lines etc. drained back to the tank...then it had so much air in it , it would not start. We gas ragged the intake..got it running ( rough) loosened all the injector lines and bled it out. drove it home, replaced the check valve, bled the injector lines again and was good to go.
