diesel turbo on gas - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2008, 06:54 PM
billlt583's Avatar
diesel turbo on gas
hi everyone i was waundering if you could run a turbo of a diesel on a gas. i have a bunch of turbos off 5.9l cummins. building a v10
Old 08-14-2008, 09:33 PM
Shelby1's Avatar
Steel Dreams
diesel turbo on gas
Don't see why not ,exhaust gas is exhaust gas ,don't matter if it's gas or diesel, turbo won't know the difference. The only thing that I can think of that could be a problem is the sizing of the turbo. I think I would do a little research on the sizing and go from there.
Good Luck
Kenny
Lost your job yet?
Keep buying foreign.
Old 08-15-2008, 07:36 AM
mcharger440's Avatar
get the big hammer
no
no ...well i gues you can but the turbos on cummins motors are very slow winding and are not made for the rpm's they will see gass engines typicaly run about 15% more rpms and they wind up and down more often point is you can it just wont last long and wont perform well ... get on ebay buy a cheap one and try it you can get them for under 250 new!!! even if you blow 2 or 3 you still dont spend what a good one would cost
Old 08-15-2008, 04:42 PM
Wiki Edits: 31
I would not buy a Cheap Chineese Turbo, they last a few thousand miles at best, and generally are not worth rebuilding after.
The Cummings 5.9 would have a Holset HX 35, some of them have variable vane setups and will not work, but the others will work. however, the HX 35 will not be big enough for a V10, as a single anyway, as it's designed to be spooled by 2.5k RPM on a 5.9L V8, so it is undersized for a gas engine.. HX 35's are common to put on engines around 250-300 CI, so you could go up to 600 CI with 2 of them
Old 08-15-2008, 04:48 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Yes; turbos can be used on either fuel... but the chances that a turbo in hand are the right configuration for your setup are slim to nil. Its kinda like just putting in an unknown cam into an engine. Without knowing its specs, you might find out you just spent a few thousand in custom plumbing and oil lines only to find out its way off for your application.
Old 08-15-2008, 05:07 PM
Wiki Edits: 31
well, it's a Holset HX 35 anyway. by itself it is too small for a gas engine over 300 CI.. but here is the compressor map for it. it is the pink line. http://www.turbobygarrett.com/turbob...mapCummins.pdf
Old 08-15-2008, 10:43 PM
KA67_72's Avatar
I'm running an HX-35 on my 302 in my Ranger. It makes 15psi and spools almost instantly. I had two on my 327 in my Chevelle. They were a little slow to spool. They're now on a 454 in the Chevelle. I haven't started it yet. I have a single HX-55 on my 350 in my Jag. It's a little slow to spool and is a little overkill, but it drops jaws when I open the hood. It doesn't match the map listed above, but according to Holset the 35 flows 60.72 lbs/min at 3:1. The 35's are quite a bit larger than a t-4. At least the one I have. I'm no expert, but I would start with a smaller turbo and upgrade if it's not big enough.
Kevin
Gas Monkey update: Discovery drops Rawlings Jon Off-Topic 140 11-19-2012 12:50 AM
Gas Thieves!!!! Weimer Hotrodders' Lounge 28 03-03-2010 03:46 PM
Classic Cars, gas, and the end of the world economy. Gladis Off-Topic 13 04-09-2007 05:51 AM
want cheaper gas prices?? plz read this sherfield2002 Hotrodders' Lounge 7 03-12-2004 06:22 AM
Backpressure = Bad.... Right?? D M N Engine 20 01-02-2004 05:53 PM
