Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Diesel turbos on gasoline engine?
Old 07-21-2006, 08:57 PM
WDCreech's Avatar
WDCreech WDCreech is offline
Grumpy Old Goat Herder
Turbos
As blob said, a turbo is a turbo. A turbo for a 400 cu. in. diesel would work on a 400 in gas engine. Then, depending on the expansion rate of the exhaust gases, you may have to make adjustments. The best way to find out is to inquire with someone that handles turbochargers. They can tell you what turbo you can use.
