Diff and gear box ratio :S - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2005, 12:25 AM
Hey
I heard that you have to have ratio between diff and gearbox right or something. Can someone elaborate on this?
Thanks
Troy
Old 03-19-2005, 12:39 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
gearing
The diff ratios are how many times the drive shaft turns (the pinion) to the amount of times the rear wheels turn (the ring gear). For example 4.11 gears. The driveshaft rotates 4.11 times every time the tires rotate once.
Each gear in the tranny has a ratio between the amount of times the motor spins (rpm) to the amount of times the end shaft of the tranny spins (driveshaft). TH 350s are 1 to 1 in drive.
You also take tire heighth into consideration. The taller the tire, the greater the circumference. The more distance traveled in one revolution.
gear swap red_rider52 Transmission - Rearend 4 01-16-2005 07:50 PM
gear & diff change emtn269 Transmission - Rearend 4 01-15-2005 07:16 PM
What's the gear ratio? JamesRS Transmission - Rearend 2 10-30-2004 07:53 PM
Determining gear ratio on an "OPEN-differential, GM 10-bolt NASCAR314 Transmission - Rearend 6 11-07-2002 09:25 PM
chnging gear ratio RAYRAY Engine 5 10-21-2002 03:22 PM
