Diff ID \help - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2006, 08:50 PM
Stroker56's Avatar
Diff ID \help
Any one help me ID the diff in my 56 Chev 2dr sedan . Only number I can find
on the outside is 3725899. Really don't want to open if I don't have to .
I think it is the original . Car was built with a 6 cyl \manual trany
Old 02-21-2006, 09:08 PM
Stroker56's Avatar
Guess what I really wanted to know was can you tell what the gears are from this number?
Old 02-22-2006, 01:39 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
That number is the housing part number, and it tells what make and model, and approximate year of manufacture.
Nothing much else if anything.
Old 02-22-2006, 01:54 AM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
If you can determine the year it was made from the numbers, can you determine what gear ratios were available in that year?
There were 3 gear ratios available for my 56 f-100 acording to the shop manual.
Mark the pinion and hub with chalk or a marker. Turn the hub and count how far the pinion turns. If its a little over 4 revolutions you know its 4.10. Its its around 3 1/2 its a 3.50. If its close to 3 3/4 then its a 3.73
Whatever chevy numbers are anyway. Sorry I am not familiar with them.
Need a little more Diff. help??? gwstang Transmission - Rearend 5 11-15-2005 08:37 AM
used diff gears rumpity_z28 Transmission - Rearend 3 06-05-2005 01:38 PM
GM 10 bolt Diff ID numbers? Gearhead forever Transmission - Rearend 8 04-27-2005 08:45 AM
ford 8 3/4 diff Snake Eater Transmission - Rearend 1 11-13-2004 12:07 PM
posi diff identification sportsman69 Transmission - Rearend 3 10-30-2004 09:44 AM
