Diff. Install Kit for 96 F-body - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-10-2009, 09:46 PM
I'll do that, I'll problably just buy it if they have it, cant be to expensive and then ill know for sure everything will work. Thanks ProStreet, you have helped me out more then anybody has this week, I tried calling richmond and other gear and axles companys and they all told me that if its a different part # it will most likely not work. Do you have a company in oregon or? Thanks again!
  #17 (permalink)
Old 01-10-2009, 09:51 PM
prostreet6t9's Avatar
Differential/Driveline
Your Welcome! Yes I'm in the Differential/Driveline/Transmission Business.
  #18 (permalink)
Old 01-10-2009, 09:59 PM
Well if I ever need some parts(which I do quite Frequently it seems) or anything I will surely let you know!
  #19 (permalink)
Old 01-11-2009, 01:40 PM
The 7.5 up to 81 used a different rear pinion bearing (89449/410 instead of 89249/210). I think pinion seal is the same up till 1999 in the cars. Does the kit come with both pinion bearings?
  #20 (permalink)
Old 01-11-2009, 03:01 PM
You might look that up again.
  #21 (permalink)
Old 01-11-2009, 03:23 PM
2043 is a 8.5 10bolt seal used in trucks up till 99. The 8610 seal is used in all 7.5 up till 99 also. The rear pinion bearing cup and cone is different in a 7.5 up till 81. The gears and other bearings are the same.
  #22 (permalink)
Old 01-11-2009, 04:54 PM
Here are some pics of what i got, the # that is on my seal is...NOK UH0525E. Hope this helps a little!
ID:	35539   Click image for larger version
ID:	35540   Click image for larger version
ID:	35541   Click image for larger version
  #23 (permalink)
Old 01-11-2009, 06:09 PM
Any parts application guide can tell you if the parts you have are correct. Go to Autozone.com and check a 1980 MonteCarlo with a 7.5 and compare to a 1996 Camaro. The rear cup and cone are different. One has a 3.0" OD race and the other is 3.125" OD. The seal and other bearings are the same. Or send the kit back and get the right one.
34 Ford body alignment 302 Z28 Body - Exterior 5 08-20-2012 07:10 PM
Which rack and pinion kit for a 55-57 chevy powerrodsmike Suspension - Brakes - Steering 4 05-02-2007 08:21 AM
Th350 Trango shift kit install lennyjay Transmission - Rearend 3 12-30-2003 06:52 PM
Install manual valve body - how hard? newchevyman Transmission - Rearend 2 11-06-2003 10:51 AM
Review of FatMan IFS Airbag install 1938 Chevy PU Grashopr Suspension - Brakes - Steering 3 08-26-2003 12:16 AM
