diff lube ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2013, 08:09 PM
diff lube ?
What's the thoughts on using Lucas oil and posi additive for replacement lube ? I installed a 75, 8.5 Camaro diff with a 308 posi in my 76 f/bird a few thousand mi. ago and I just wanted to renew the lube after it was driven awhile. It was a used one with lower mileage on it but I wasn't sure how long it'd been setting before I put it in . I put new brgs. and fluid in when I installed it . Guess I just want to be sure as I can be that I do a good job at keeping it working and serviced properly !!! Thanks
Old 10-21-2013, 06:03 AM
big gear head's Avatar
High Performance Rear Ends
That should work fine. Just be sure that you use the GM additive and not the crap that they sell at the auto parts sotres.
Old 10-21-2013, 11:19 AM
In manual gearboxes, Lucas gives us fits. I shoulda known, Any product named Lucas brings back nightmares about wiring a TR4
Old 10-21-2013, 01:22 PM
75W90 or 75W140 Synthetic
I suggest using a synthetic 75W90 gear lube with Ford's Posi additive. The synthetic will remain at a constant viscosity regardless of temperature, as well as keep the heat down in the rear.
Old 10-21-2013, 04:58 PM
I used Amsoil in most of the rear ends that I built for about 15 years. I only had problems with 2 cone type differentials. The Ford additive is also good.
Fun at Mr Lube! Dave57210 Hotrodders' Lounge 0 09-01-2011 08:59 PM
Assembly Lube? Minor Problem Hotrodding Basics 1 01-07-2009 07:41 AM
Piston lube?? sexypizzaman Engine 21 09-14-2007 07:04 PM
cam lube KeithB123 Engine 5 02-03-2005 09:10 AM
Cam Lube MI2600 Engine 9 03-31-2004 07:25 AM
