diff swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2007, 08:15 PM
I have a 1967 rs/ss convertible in rough shape.It needs a differential.
I have a 2001 explorer 373 traction loc,and was wondering if it would could be made to fit my camaro.
Old 09-24-2007, 08:46 PM
is the track width similar?
Shane
Old 09-25-2007, 08:25 AM
diff swap
It is 1 inch wider
Old 09-25-2007, 12:14 PM
Yeah, other than the different track width, different lug bolt pattern, different brakes, different spring perch spacing, different shock mounts, and different pinion flange, it's a bolt-in.
Old 09-25-2007, 03:11 PM
S10xGN's Avatar
Gotta love a turbo!
What do you want to spend? Here's the 2002 cost breakdown on putting a (narrowed by 2") Ranger 8.8" rear in my S-10, very similar to you project and a lot cheaper than a 12 bolt or 9". All critical work was done by either Pyle Bros. or Moser.
  • Used 8.8" 3.73 locker @ $400.00
  • Freight @ $85.00
  • Narrow left axle tube @ $125.00
  • New spring perches (+ welds) @ $65.00
  • Pair new brake drums @ $81.00
  • Shipping to Moser @ $28.00
  • Redrill stock RH axle and new drums @ $45.00
  • New Moser RH axle (for LH tube) @ $115.00
  • New studs @ $15.00
  • Shipping back @ $35.00
  • Total = $994.00
HTH,
Russ
Old 09-25-2007, 03:17 PM
leldai73's Avatar
Its just metal,you're the boss
why would you want to get rid of the stock axle in an "RS/SS" Camaro?
Old 09-25-2007, 06:50 PM
"It needs a differential."
One inch shouldnt be much of a problem.....but it wont be as ctrong.
Shane
Old 09-25-2007, 07:13 PM
diff swap
Does anyone know a machine shop in the atlanta area that can drill my 8.8 ford axles & rotors to a 5 x 4.75 bolt pattern.
Old 09-25-2007, 07:54 PM
This may be of some help
http://switchboard.com/swbd.main/dir...&search=Search
Shane
Cam swap Questions wayfast77 Engine 3 10-18-2006 05:52 AM
Rear diff swap. g_mac13 Transmission - Rearend 9 01-12-2005 11:42 PM
differential swap 454impala Transmission - Rearend 1 11-13-2003 01:16 AM
