LinkBack | Thread Tools |
Here's a website with a good comparison between the different types:
http://www.sounddeadenershowdown.com/ |
I did exactly what you are describing. I used the 8" wide rolls of Peel and Seal because it was easier to install inside door panels. In addition I sprayed both the backside of the Peel and Seal and the inside of the doors with 3M trim adhesive for added stick. I don't believe the Peel and Seal is asphalt, I think it might be butyl rubber. It's much too sticky to be asphalt.
Vince |
I called a roofing supply place and they did not really know any product by the name polymeric mastic, and didn't have any "ice guard" watersheild stuff either. Guess I'll have to go to Lowe's or HDepot. Which one of those would have the Peel and Seal by name? If that truly is butyl rubber, that would be the stuff to use. The guy on the sound deadner showndown said that the butyl stuff was way better than the asphalt (cheaper) types. Higher heat resistance, better stick, etc etc. Thanks for any info guys . . .
I used about 70ft^2 of the P&S on my S10 (my buddy has the other 30ft^2 in his 68 chevy short bed and it handles the heat of his headers quite well) but I have only laid down a few ft^2 of the Polymeric Mastic. I do however think the Polymeric Mastic is the better product. Because it doesn't have the rigidness of the aluminum foil it is easier to get into complex curved areas without creases (using heat of course). It also sticks better to automotive paint (both stick with a vengeance to the NoiseKiller paint!) Last edited by Triaged; 01-20-2007 at 02:42 PM. |
I put in ice shield about 10 years ago. I am redoing my truck so it will have to come out...only to be replaced again with ...what else ice shield. The truck was never garaged so it took on all the elements. It worked great as far as I am concerned
Look at this thread also. There is some good info. sound deadening??? |
Now that we know that P & S is indeed Asphalt based, I remember reading somewhere in all of this that the Asphalt type will emit a smell, I assume when exposed to Summer Heat-anyone experienced this?
I have had no problems with my P&S in my truck in the hot SoCal sun that are the fault of the P&S. Interior temps get around 140F in the summer (with tinted windows and a windshield shade). I could smell the stuff for maybe a week after installing it...but to me it smelled as much of adhesive as asphalt. The only places that I have had problems with it pealing off are because of poor instillation on my part. I left WAY too many bubbles in it. Because of the asphalt in it poking a hole in it to vent the bubble isn't exactly easy. You need more like a 1/2" gash...of which I have many...to get the air out. I have tried to peal off and redo some of the areas that I messed up...not going to happen.
MY black truck went through the So. Az. summer last year with the A/C on and all I could smell was the leather seat, I installed P&S on everything but the windows !! |
I was worried about potential smell so I put duct tape over the seams. probably overkill but there has been zero smell ever and I live in georgia.
Funny, I've recorded temps of 180 degrees in my car and I live in Canada. The el cheapo home depot stuff designed for houses that fails the most basic tests done would no doubt never even survive to winter. Winter here is usually as low as -40 at least once per year and as my garage is not heated it would be subject to both extremes. I'm going to do MY project right and use that second skin audio's Dampener, just need to figure out how much I need to do my floor, roof, doors and behind the rear seat.
| Recent Interior posts with photos |
