difference 305 ecm/350 ecm...need help thanx - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2008, 06:50 PM
im not sure if this is the section i need to be in....
I have a 91 caprice, it has tbi 305 in it....i am putting a 350 in it and i was wondering how i could find out what ecm module i could use so it would work with my caprice.....can it only be out of another caprice or is there other cars the ecm would work for......
I believe my throttle body is controled by the ecm and the 350 would need more gas, the ecm would have to be changed in order for the motor to operate better correct.....im not sure, i need to know if i can just get a ecm that had a tbi 350 in it and wonder if it would work.....im not sure what to do or where to look????.....Thanks for a response
Old 10-05-2008, 08:28 PM
The ECM is the same all you need to change is the PROM. You should be able to get one from GM still.
Old 10-06-2008, 10:07 AM
Bench racer
Go here, do a search, read lots, be happy
http://www.thirdgen.org/techboard/dfi-ecm/
Lots of great GM ECM info here (not just f-bodies). Make sure to search and read BEFORE asking questions! There are plenty of helpful folks there but they can get a little testy if you ask a simple question that has had 15 in-depth tutorials written on it. After you read if you have specific questions fire away...
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
More head questions for the head gurus, seen 305 heads with 2.02's 4speed57 Engine 10 07-13-2005 02:14 AM
305 cam carb manifold stickshift Engine 6 04-12-2005 03:46 PM
350 to 305 swap 78Z Engine 10 02-06-2005 01:42 AM
Suggestions for my 305 Chevy Express engine? wrmason3 Engine 2 09-14-2002 05:51 AM
